混频器以广泛的射频范围来提高微波传输
关键词:微波发射器 LTC5576 活性双平衡混频器
时间:2015-05-27 16:25:25      来源:中电网
国际即时新闻(原文:英文)
Mixer has wide RF range to enhance microwave transmission
Offered with a wide RF frequency range, from 3.0 to 8GHz, the LTC5576 is an active double balanced upconversion mixer from Linear Technology.
It enhances microwave transmitter and upconversion performance, says the company, with linearity of 25dBm OIP3 and conversion loss of only 2dB at 8GHz. The integrated input buffer needs only a 0dBm level drive, effectively eliminating an external amplifier circuit. An integrated RF balun transformer design extends output frequency bandwidth while enabling single-ended operation across the frequency range.
The IF input is continuous 50? differential matched from 30MHz to over 3GHz. With a proper external balun transformer, the upper range can be extended to over 6GHz, says the company.An active double balanced mixer core with port-to-port isolation ensures low leakage to minimise external filtering in order to meet regulatory out-of-band emission requirements. Extended frequency capability addresses applications such as short-range microwave backhauls, 5.8GHz cellular basestations and wireless repeaters. The dynamic range supports the performance requirements of wireless test equipment, radar receivers and satellite communications.
The LTC5576 is more rugged than other integrated microwave mixers, says the company, with its improved ESD rating of 2,500V human body model (HBM) on all pins. Housed in a 16-lead, 4.0 x 4.0mm QFN package it operates from -40 to 105°C case temperature to support extended environmental operating temperature. The mixer is optimised for single 5V supply operation, with a nominal supply current of 99mA. Power consumption can be reduced by powering from a 3.3V supply (with slightly reduced performance). An enable pin disables the IC, which when deactivated, draws only 1.3mA typical standby current. This pin can be used to turn the device on and off rapidly in less than 0.6µs, supporting time-division duplex (TDD) or burst-mode type radios.
中文自动翻译,供参考
混频器以广泛的射频范围来提高微波传输
提供具有广泛的RF频率范围,从3.0至8GHz的LTC5576是凌特活性双平衡混频器上变频。
它提高了微波发射器和变频的表现,说公司,与25dBm的OIP3线性度和转换损耗仅为2dB为8GHz频率处。集成的输入缓冲器只需要0dBm的水平驱动器,有效地消除外部放大器电路。集成RF平衡 - 不平衡变压器设计扩展输出频率带宽,同时实现单端工作在整个频率范围内。中频输入是连续50?从30MHz到3GHz的多差分相匹配。用适当的外部平衡 - 不平衡变压器,该上限范围可以扩展到6GHz的多,说公司。
活性双平衡混频器内核与端口至端口隔离,确保低漏电,以便满足了带外监管要求的排放减少外部滤波。扩展频率能力满足应用,如短程微波回程,5.8GHz的蜂窝基站和无线中继器。动态范围支持的无线测试设备,雷达接收机和卫星通信的性能要求。
该LTC5576是比其他集成微波混频器更坚固耐用,该公司表示,与2,500V人体模型(HBM)上的所有引脚的ESD改善评级。采用16引脚,4.0×4.0毫米QFN封装,它工作在-40℃至105℃温度的情况下,支持扩展的环境工作温度。该混频器专为5V单电源操作而优化,具有99毫安标称电源电流。功率消耗,可从3.3V电源(略有降低性能)供电降低。一个使能引脚禁用IC,它停用时,功耗仅为1.3毫安典型待机电流。该引脚可以用于打开和关闭设备迅速在小于0.6μs,支持时分双工(TDD)或突发模式型收音机。
*为了帮助广大工程师快速了解国际半导体最新资讯和新品,中电网最新推出国际新闻、新品栏目,配备自动翻译,供参考。
2019“芯动北京”中关村IC产业论坛即
