宽带混频器整合LO倍频器,实现宽频率范围
关键词:LO倍频器 双平衡混频器 外部大功率LO放大器电路 低频合成器
时间:2015-08-12 10:31:43      来源:中电网
国际即时新闻(原文:英文)
Wideband mixer has integrated LO frequency doubler for wide frequency range
Able to operate as an up-converter or down-converter, the LTC5549 is a double-balanced mixer from Linear Technology. It has a wide RF range from 2.0 to 14GHz and offers high linearity of 24.4dBm IIP3 at 9GHz.
The converter enables efficient microwave transmitter and receiver designs with an integrated LO buffer that needs only a 0dBm drive level – effectively eliminating an external high power LO amplifier circuit. An integrated on-chip, switchable frequency doubler for LO signal allows the use of lower cost, commonly available low frequency synthesisers. A wideband integrated balun transformer is optimised to extend RF bandwidth while enabling single-ended operation. The IF port also has wide bandwidth up to 6GHz. All three ports are 50? matched. The mixer offers high port-to-port isolation, minimising undesirable LO leakage, and easing external filtering requirements.
 Target microwave applications include microwave backhaul, high unlicensed band LTE-Advanced base stations, satellite broadband radios, radar systems, X-band and Ku band transceivers, test equipment and satellite modems.
 Protection is 2,000V ESD human body model (HBM) rating on all pins.
 The mixer is optimised for single 3.3V supply operation, drawing a nominal supply current of 115mA. An enable pin disables the IC, which when de-activated enables the device to draw only 100?A maximum standby current. The enable pin can be driven directly to turn the device on and off rapidly in less than 0.2?s, supporting time-division duplex or burst mode type radios.
 The device is available in a tiny 12-lead, 3mm x 2mm plastic QFN package. It operates from -40 to 105°C case temperature to support extended environmental operating temperature.
中文自动翻译,供参考
能够作为上变频器或下变频器,所述LTC5549是从线性技术的双平衡混频器。它具有广泛的射频范围从2.0〜14GHz,并提供24.4dBm IIP3的高线性度的9GHz的。
该转换器能够有效地微波发射器和接收器的设计与仅需要0dBm的驱动电平的集成LO缓冲器 - 有效地消除外部的高功率LO放大器电路。一个集成在芯片上,可切换倍频为LO信号允许使用成本较低,通常可获得的低频率合成器的。一个宽带综合平衡 - 不平衡变压器优化,延长射频带宽,同时实现单端工作。 IF端口还具有较宽的带宽高达6GHz。所有三个端口50?匹配。该混频器提供高端口至端口隔离,最大限度地减少不良的LO泄漏,并缓解外部滤波要求。
目标微波应用包括微波回程,高开放频段的LTE-Advanced的基站,卫星宽带无线电,雷达系统,X波段和Ku频段收发器,测试设备和卫星调制解调器。
保护是对所有引脚的ESD 2,000V人体模型(HBM)的评级。
该混频器专为3.3V单电源操作而优化,绘制115毫安标称电源电流。一个使能引脚禁用IC,它取消激活后使该器件能够画出只有100?一个最大待机电流。使能引脚可以直接驱动到打开和关闭设备迅速在小于0.2?的,支持时分双工或突发模式型收音机。
该器件采用纤巧12引脚的3mm x 2mm的塑料QFN封装。它的工作温度范围为-40至105°C的温度,以支持扩展的环境工作温度。
*为了帮助广大工程师快速了解国际半导体最新资讯和新品,中电网最新推出国际新闻、新品栏目,配备自动翻译,供参考。
服务器和数据中心电源:用于保护、控制和诊
