相位对焦CMOS图像传感器支持4K
关键词:相位对焦CMOS图像传感器 背面照度(BSI)CMOS图像传感器 自动对焦系统
时间:2015-08-24 10:40:30      来源:中电网
国际即时新闻(原文:英文)
Phase detection auto-focus CMOS image sensors support 4K
Backside illumination (BSI) CMOS image sensors from Toshiba are equipped with Phase Detection Auto-Focus (PDAF). PDAF locks in focus at speeds much faster than the auto-focus systems currently used in smartphones and tablets. The 8Mpixel T4KA3-121, the 16Mpixel T4KC3-121, the 13Mpixel T4KB3-121 and the 20Mpixel T4KA7-121 have image brightness boosted by up to a factor of four, with the company’s Bright Mode technology. The sensors also support high dynamic range to capture natural images of scenes, with a high contrast ratio to prevent over- and underexposed images.
The T4KA3-121 achieves output speeds of up to 30frame/s at full 8MP-resolution – with power consumption figures of 140mW or less. Full-HD outputs are supported at frame rates of up to 60frame/s, and HD outputs are supported at 120frame/s in normal mode and 240frame/s in Bright Mode.
The T4KB3-121 and T4KC3-121 achieve output speeds of up to 30frame/s at 4K2K resolutions, full-HD at frame rates of up to 60frame/s, and HD outputs at 120frame/s.
The T4KA7-121 achieves output speeds of up to 22frame/s at 20Mpixel resolution, 24frame/s at 18.8Mpixel and 28frame/s at 16.3Mpixel, with a power consumption of 440mW.
中文自动翻译,供参考
相位对焦CMOS图像传感器支持4K
东芝背面照度(BSI)CMOS图像传感器配备了相位检测自动对焦(PDAF)。 PDAF锁定在对焦的速度比目前在智能手机和平板电脑使用的自动对焦系统快得多。该8Mpixel T4KA3-121的16Mpixel T4KC3-121的13Mpixel T4KB3-121和20Mpixel T4KA7-121有图像的亮度提高多达四个因素,该公司的明亮模式的技术。该传感器还支持高动态范围来拍摄场景的自然图像,具有高对比度,以防止过压和曝光不足的图像。
该T4KA3-121实现了高达30frame / s的全800万像素的高分辨率输出速度 - 与140mW的或更小的功耗值。全高清输出以高达60frame /秒的帧速率的支持,以及HD输出在正常模式和240frame / s的明亮模式120frame / s的支持。
所述T4KB3-121和T4KC3-121实现高达30frame / s的4K2K分辨率,全高清在高达帧频60frame / s的输出速度,以及HD输出的120frame /秒。
所述T4KA7-121达到高达22frame / s的20Mpixel分辨率输出速度,24frame / s的18.8Mpixel和28frame / s的16.3Mpixel,具有440MW的功率消耗。
*为了帮助广大工程师快速了解国际半导体最新资讯和新品,中电网最新推出国际新闻、新品栏目,配备自动翻译,供参考。
