管理程序提供存储器管理和Windows 10支持
关键词:虚拟化开销 非一致内存访问(NUMA) 本地存储器控制器
时间:2015-09-08 16:43:56      来源:中电网
国际即时新闻(原文:英文)
Hypervisor offers memory management and Windows 10 support
Version R4.3 of the RTS hypervisor has been released by Real-Time Systems. It scales from Atom processors to XEON based systems and designed to support the sixth generation Intel Core processors (codenamed Skylake). Memory management allows relocation of RTOS without virtualisation overhead, says the company, and eliminates jitter on NUMA (non uniform memory access) based hardware.
Users can relocate Guest Operating Systems in memory to deploy 32bit operating systems in memory above the addressable limit of 4Gbyte or to load and run multiple kernels linked to the same physical address in parallel without any virtualisation overhead, deterministically and in hard real-time.
Users of high-end systems, running the RTS Hypervisor on multi-socket XEON platforms, found in medical machines, for example, can use the NUMA architecture, where each physical processor (NUMA node) may have memory connected to its own local memory controller. This can now assign memory of specific NUMA nodes exclusively to an OS. This reduces memory access times and jitter, as simultaneous, competing memory access by multiple OS is avoided.
Microsoft Windows 10 and Concurrent Computer’s RedHawk 7 is now supported by the hypervisor. Security features include access rights for shared memory partitions or the new rights management for the use of programming interfaces (APIs) to start, stop or otherwise control guest operating systems.
中文自动翻译,供参考
在RTS虚拟机管理程序的版本R4.3已经发布实时系统。它规模从Atom处理器为Xeon处理器为基础的系统,旨在支持第六代英特尔酷睿处理器(代号为SKYLAKE微架构)。内存管理允许搬迁的RTOS没有虚拟化的开销,该公司表示,并消除了抖动对NUMA(非一致内存访问)的基础硬件。
用户可以重新定位的客户机操作系统在内存到内存配置32位操作系统上面4Gbyte的可寻址限制或加载和运行链接到并行同一个物理地址的多个内核没有任何虚拟化开销,确定性和硬实时。
高端系统的用户,多插座XEON平台上,在医疗机械中运行的RTS管理程序,例如,可以使用NUMA架构,其中,每个物理处理器(NUMA节点)可以具有存储器连接到其自身的本地存储器控制器现在,这可以指定特定的NUMA节点的内存专门的操作系统。这降低了内存访问时间和抖动,通过多个操作系统同时,竞争的内存访问是可以避免的。
微软的Windows 10和并行计算机的红鹰7现在由虚拟机管理程序的支持。安全特性包括用于共享内存分区的访问权限或者使用的编程接口(API)的新的权限管理,启动,停止或以其他方式控制客户机操作系统。
*为了帮助广大工程师快速了解国际半导体最新资讯和新品,中电网最新推出国际新闻、新品栏目,配备自动翻译,供参考。
友荐云推荐
