Silicon Labs公司扩大数字隔离产品组合
关键词:微型逆变器 Si86xxxT数字隔离器 电容隔离技术
时间:2015-11-03 13:48:28      来源:中电网
国际即时新闻(原文:英文)
Silicon Labs Expands Digital Isolation Portfolio with Robust 10 kV Surge Protection
AUSTIN, Texas--(BUSINESS WIRE)--Silicon Labs (NASDAQ: SLAB), a leading provider of digital isolation technology for industrial automation and Internet infrastructure, today introduced a new family of multi-channel digital isolators featuring a high-voltage isolation barrier designed to withstand 10 kV surge hits. Based on Silicon Labs’ proprietary capacitive isolation technology, the new Si86xxxT digital isolator family provides robust protection against secondary lightning strikes and increases system reliability in a wide range of demanding industrial applications.
Silicon Labs’ Si86xxxT digital isolator family delivers the industry’s fastest, most accurate timing specifications, highest noise immunity and reliability, lowest electromagnetic noise emissions and longest lifetimes under high-voltage conditions. The Si86xxxT digital isolators are ideal for applications that must withstand a 10 kV hit such as microinverters, base station power supplies, process manufacturing equipment, motor controls and drives, industrial uninterruptible power supplies, metering equipment and battery management systems for electric vehicles.
Developers of industrial applications expect reinforced isolation products to provide fail-safe protection from secondary lightning strikes, especially in applications where equipment is installed outdoors and where exposed cables or wires are vulnerable to lightning. In addition to requiring surge ratings of up to 10 kV, industrial equipment developers also demand isolation products with fast timing, high noise immunity, long lifetimes at high voltages, and a wide VDD and temperature range. These specifications help developers enhance the efficiency, effectiveness and safety of their system designs. The Si86xxxT family provides a best-in-class 10 kV isolation solution by satisfying all of these design requirements.
The Si86xxxT family includes a wide range of dual- to quad-channel devices in wide-body packages to accommodate diverse application needs with higher isolation ratings. Pin-compatible with existing digital isolators from Silicon Labs and other isolation suppliers, the Si86xxxT family offers substantial data rate, propagation delay, power, size, reliability and external bill of materials (BOM) advantages over legacy isolation technologies.
The operating parameters of Si86xxxT digital isolators remain stable across wide temperature ranges and throughout the device service life for ease of design and highly uniform performance. The 10 kV surge capability qualifies Si86xxxT isolators as “Reinforced VDE” components, a standard of high importance for many industrial, telecom and automotive applications. Long lifetimes are particularly important to meet typical product lifetime for industrial uses.
All Si86xxxT digital isolators have Schmitt trigger inputs for high noise immunity, and these highly integrated devices only require VDD bypass capacitors, reducing BOM cost and complexity. The Si86xxxT devices support data rates up to 150 Mbps with propagation delays of 10 ns. Enable inputs provide a single point of control for enabling and disabling the output drive.
“For many industrial and green energy applications, 10 kV isolation is a must-have requirement to protect sensitive equipment from secondary lightning strikes and power surges,” said Ross Sabolcik, vice president of access and isolation products at Silicon Labs. “We have expanded our digital isolation portfolio to meet this critical customer need. In addition to providing robust 10 kV surge protection, our new Si86xxxT digital isolators lead the industry in timing specifications, noise immunity, reliability and high-voltage lifetime.”
Si86xxxT Digital Isolator Family Highlights
• Robust 10 kV surge withstand capability for secondary lightning protection
• Fastest, most accurate timing specs with low propagation delay (10 ns) and low skew (1 ns)
• Highest noise immunity (CMTI) of 100 kV/µs and lowest electromagnetic noise emissions (20 dB lower than competing digital isolators)
• Long lifetimes under high-voltage conditions (100 years at 1000 V)
• Low-power isolation solution with 1.8 mA maximum power per channel at 10 Mbps
• Flexible ordering options: multiple channels, package configurations and a selectable fail-safe operating mode to control the default output state during power loss
Pricing and Availability
Samples and production quantities of the Si86xxxT digital isolators are available now in a variety of compact wide-body packages. Pricing in 10,000-unit quantities begins at $1.52 for a two-channel Si862xxT device; $2.17 for a three-channel Si863xxT device; and $2.93 for a four-channel Si864xxT device. (All prices are in USD.) The Si86xxTISO-KIT evaluation kit, priced at $29.00 (USD MSRP), is available now to help developers evaluate and implement 10 kV isolation barriers in their applications. For additional information about Silicon Labs’ Si86xxxT digital isolator family and to purchase samples and development tools, please visit www.silabs.com/isolation.
中文自动翻译,供参考
德克萨斯州奥斯汀​​ - (美国商业资讯) - Silicon Labs公司(纳斯达克股票代码:SLAB)的数字隔离技术,工业自动化和网络基础架构领先供应商,今天宣布推出多通道数字隔离器的一个新系列,具有高电压隔离屏障设计,可承受10千伏浪涌命中。基于Silicon Labs的专利电容隔离技术,新Si86xxxT数字隔离器系列提供了强大的保护,防止二次雷击,提高了系统的可靠性在多种要求苛刻的工业应用。
Silicon Labs公司扩大数字隔离产品组合与强大的10千伏浪涌保护
Silicon Labs的Si86xxxT数字隔离器系列提供了业界最快,最精确的计时规格,最高的抗干扰性和可靠性,低电磁噪声排放和最长的寿命在高电压条件下。该Si86xxxT数字隔离器非常适合必须承受一个10千伏命中,如微型逆变器,基站电源,加工制造设备,电机控制和驱动,工业不间断电源,计量设备及电池管理系统,电动汽车的应用。
工业应用的开发人员期望增强隔离产品,以提供从次级雷击失效保护,特别是在设备安装在室外的应用程序和当暴露电缆或电线容易受到雷击。除了要求高达10千伏浪涌额定值,工业设备等也需要隔离产品具有快速的时序,高抗干扰,长寿命在高电压和宽VDD和温度范围内。这些规范帮助开发人员提高他们的系统设计效率,有效性和安全性。该Si86xxxT家庭提供了满足所有这些要求,设计最佳的一流的10千伏隔离解决方案。
该Si86xxxT家族包括一系列的双在宽体封装的四通道器件,以适应更高的额定隔离不同的应用需求。引脚兼容,Silicon Labs和其它隔离供应商现有的数字隔离器,该Si86xxxT系列提供了大量的数据传输速率,传输延迟,功耗,尺寸,可靠性和材料外清单(BOM)优于传统的隔离技术。
的Si86xxxT数字隔离器的运行参数保持稳定整个较宽的温度范围和整个设备的使用寿命,便于设计和高度一致的性能。 10千伏浪涌能力资格Si86xxxT隔离器为“增强VDE”组件,具有高度重要性的许多工业,电信和汽车应用的标准。长寿命是特别重要的,以满足典型的产品生命周期的工业用途。
所有Si86xxxT数字隔离器具有施密特触发器输入,高抗噪声能力,而这些高度集成的设备只需要VDD旁路电容,降低了BOM成本和复杂性。该Si86xxxT设备支持数据传输速率高达150 Mbps的为10 ns的传播延迟。使能输入提供了一个单一的控制点的启用和禁用输出驱动器。
“对于许多工业和绿色能源的应用,10千伏隔离是必须具备的要求,以保护敏感设备免受二次雷击和电涌,”罗斯Sabolcik,接入和隔离产品的Silicon Labs公司副总裁。 “我们扩大了我们的数字隔离产品组合,以满足这个关键的客户需求。除了提供强大的10千伏浪涌保护,我们的新Si86xxxT数字隔离器引领时序规范,抗噪性,可靠性和高电压寿命的行业。“
Si86xxxT数字隔离器系列产品的亮点
•强大的10千伏浪涌承受二次防雷能力
•最快,最精确的计时功能与低传输延迟(10纳秒)和低歪斜(1纳秒)
•最高的抗噪声能力100千伏/微秒(CMTI)和最低的电磁噪音(20分贝低于竞争的数字隔离器)
•在高电压条件下长寿命(100年间1000伏)
•低功耗隔离,每通道1.8毫安最大功率为10 Mbps解决方案
•灵活的订购选项:多种渠道,包配置和可选的故障安全操作模式来控制电源损耗过程中的默认输出状态
价格及供货情况
样品和量产批量Si86xxxT数字隔离器现可提供各种小型宽体封装。在10,000件的批量定价开始在$ 1.52双通道Si862xxT装置; $ 2.17三通道Si863xxT装置;和$ 2.93四通道Si864xxT设备。 (所有价格均为美元)的Si86xxTISO-KIT评估套件,售价为$ 29.00(美元建议零售价),现在可帮助开发人员评估和执行他们的应用10千伏隔离屏障。有关Silicon Labs的Si86xxxT数字隔离器系列的更多信息,并购买样品和开发工具,请访问www.silabs.com/isolation。
*为了帮助广大工程师快速了解国际半导体最新资讯和新品,中电网最新推出国际新闻、新品栏目,配备自动翻译,供参考。
友荐云推荐
