安富利推出多协议工业以太网解决方案
关键词:MicroZed工业以太网4.0套件 Anybus技术HMS工业网络 传感器
时间:2016-03-15 10:00:49      来源:中电网
国际即时新闻(原文:英文)
Avnet Introduces Multi-Protocol Industrial Ethernet Solution
PHOENIX--(BUSINESS WIRE)--Avnet, Inc. (NYSE: AVT), a leading global technology distributor, today introduced the new MicroZed™ Industry 4.0 Ethernet Kit (I4EK), enabling multi-protocol Industrial Ethernet solutions based on the Xilinx® Zynq®-7000 All Programmable SoC and Anybus® technology from HMS Industrial Networks. Offering seamless hardware and software integration across networks, the I4EK allows designers creating leading edge applications in smart factory automation such as networked sensors, actuators and motor control to avoid months of development and debug of their embedded systems.
The I4EK out-of-box reference design demonstrates a Slave EtherCAT®controller executed entirely in the programmable logic of the Xilinx Zynq-7000 All Programmable SoC. A soft master is executed on a host PC using Beckhoff TwinCAT software. Reference designs for EtherCAT, Ethernet Powerlink, PROFINET® RT/IRT, EtherNet/IP and Modbus-TCP protocol are provided by the Anybus IP from HMS Industrial Networks. In order to help speed development, no fees are required for evaluation versions of these reference designs and they are enabled after signing an evaluation license with HMS.
Customers can use the I4EK to evaluate HMS Anybus® IP for Xilinx built upon the award-winning Anybus CompactCom™ technology, which provides the most widely used protocols with a unified API. Deployed products are licensed with a tiny single-wire security chip.
“This kit brings together production-ready embedded hardware and IP to simplify the task of developing equipment that supports multiple high performance Industrial Ethernet protocols,” said Matt Brown, technical marketing engineer, Avnet Electronics Marketing. “Designers use the MicroZed SOM and Anybus IP for evaluation, prototype, and product deployment, which takes months off product development cycles.”
“Avnet's new I4EK provides a fast and cost-efficient way for product managers, system architects and developers to prototype and create differentiated products with the unmatched versatility of Xilinx Zynq-7000 All Programmable SoCs and the field-proven performance and compatibility of HMS Anybus IP for all major Industrial Ethernet slaves,” said Michael Zapke, marketing manager for industrial applications from Xilinx. “This is how Avnet, HMS and Xilinx are helping to drive the vision of the Industrial Internet of Things (IIoT) and Industry 4.0.”
“HMS has created a suite of the five major Industrial Ethernet protocols within Anybus IP so engineers designing with the Xilinx Zynq-7000 All Programmable SoC can now have the option of using PROFINET, EtherNet/IP, EtherCAT, Powerlink and Modbus TCP with the same interface and functionality,” said Christian Bergdahl, Product Marketing Manager at HMS. “Using the MicroZed Industry 4.0 Ethernet Kit (I4EK) from Avnet, and downloading the Anybus IP demo firmware from HMS, designers can easily evaluate the best-in-class Anybus IP for Zynq.”
MicroZed™ Industry 4.0 Ethernet Kit includes:
·MicroZed 7020 SOM
·ISM Networking FMC Module II
·MicroZed FMC Carrier
·JTAG HS3 High Speed Xilinx Programming Cable
·microSD card
·Ethernet and USB cables
·12V power supply
·Quick Start Card
·EtherCAT reference design and Anybus IP tutorial downloads
中文自动翻译,供参考
安富利推出多协议工业以太网解决方案
凤凰 - (BUSINESS WIRE) - 安富利公司(NYSE:AVT)是全球领先的技术分销商,今天宣布推出新的MicroZed™工业以太网4.0工具包(I4EK),使基于Xilinx多协​​议工业以太网解决方案®Zynq®-7000所有Programmable SoC和Anybus®技术HMS工业网络。跨网络的无缝提供硬件和软件的集成,I4EK让设计师创造了智能工厂自动化前沿应用,如联网的传感器,执行器和电机控制,以避免他们的嵌入式系统的开发和调试个月。
该I4EK出的现成参考设计演示了从EtherCAT®controller在赛灵思ZYNQ-7000全可编程系统芯片的可编程逻辑完全执行。软师傅正在使用的Beckhoff的TwinCAT软件的PC主机上执行。而EtherCAT,以太网Powerlink,PROFINET®RT / IRT,以太网/ IP™和Modbus-TCP协议的参考设计由HMS工业网络的Anybus的IP提供。为了帮助高速发展,不需要任何费用,这些参考设计的评估版本和他们签署与HMS评估许可证后启用。
客户可以使用I4EK评估HMSAnybus®IP赛灵思建立在屡获殊荣的Anybus CompactCom™技术,该技术提供了一个统一的API使用最广泛的协议。部署产品行货带一个小单线安全芯片。
“此套件汇集了生产就绪的嵌入式硬件和IP,以简化开发支持多种高性能工业以太网协议设备的任务,”马特·布朗,技术营销工程师,安富利电子元件部说。“设计师使用MicroZed SOM和IP的Anybus评估,原型和产品部署,这需要数月的产品开发周期。”
“安富利的新I4EK产品经理,系统架构师和开发人员提供了一种快速,经济高效的方式与赛灵思ZYNQ-7000全可编程系统级芯片的无与伦比的多功能性和实地验证的性能和HMS的Anybus IP的兼容性为原型,打造差异化产品所有主要的工业以太网的奴隶,“营销经理赛灵思工业应用迈克尔Zapke说。 “这是安富利,HMS和Xilinx如何帮助推动物联网产业因特网(IIoT)和工业4.0的视力。”
“HMS已经创造了一套的Anybus IP内的五大工业以太网协议,因此工程师与赛灵思ZYNQ-7000所有Programmable SoC的设计现在可以使用的选项PROFINET,以太网/ IP,EtherCAT的,Powerlink上和Modbus TCP与同界面和功能,“基督教贝里达尔在HMS产品营销经理说。 “安富利使用MicroZed工业以太网4.0工具包(I4EK),并从下载的HMS的Anybus IP演示固件,设计人员可以轻松地评估最佳的一流的Anybus IP为ZYNQ。”
MicroZed™工业以太网4.0套件包括:
•MicroZed 7020 SOM
•ISM网络FMC模块II
•MicroZed运营商FMC
•JTAG HS3高速赛灵思编程电缆
•microSD卡
•以太网和USB电缆
•12V电源
•快速入门卡
•EtherCAT的参考设计和IP的Anybus下载教程
*为了帮助广大工程师快速了解国际半导体最新资讯和新品,中电网最新推出国际新闻、新品栏目,配备自动翻译,供参考。
友荐云推荐
